BT.com
Wishlist
ION Audio DJ2GO Portable DJ Controller for PC & Mac
ION Audio DJ2GO Portable DJ...
£54.09
£54.09
Add to wishlist
Delivery
Standard Due date unavailable
DJ2GO is not only the most portable DJ controller you'll find, it's also incredibly easy to use. This highly capable DJ controller will enpower you with the ability to mix all of your favorite music virtually anywhere.
DJ2GO has all of the essential tools you need to begin DJing right away. Just install the included Virtual DJ LE Lite software, connect DJ2GO to your Mac or PC using the included USB cable and you're ready to go. The Virtual DJ software will detect your music files automatically and you can then select songs using DJ2GO's music scrolling knob. The software and hardware work together seamlessly: on screen, the Virtual DJ software mimics every adjustment you make on the DJ2GO hardware in real-time, making for a intuitive music-mixing experience.
Even professional DJs will find DJ2GO to be an ultra-convenient addition to their arsenals. DJ2GO is ideal for smaller venues where space is limited and it's also a perfect backup controller.
DJ2GO gives you a tactile feel that can't be matched by DJing with just your computer mouse and keyboard. In fact, with DJ2GO there's virtually no need to touch your mouse or keyboard while performing. Everything you need to do, from selecting songs and cueing, to beat-matching and volume adjustment can be controlled by DJ2GO's generous array of faders, knobs and bright, backlit buttons. DJ2GO weighs just 13 oz. but provides a layout that DJs prefer, including two platters, a crossfader, pitch and level controls as well as Deck A, Deck B, Master and Headphone gain controls. Sync and headphone buttons allow you to instantly sync two tracks and monitor either deck section.
ION DJ2GO - DJ controller
DJ controller
Bus Type
USB
DJ controller
Bus Type
USB
Mixer
Control Types
Knobs, faders, jog wheels
Software Included
Virtual DJ LE Lite
USB bus powered
Connector Type
1 x USB
Scroll to top
