BT.com
Wishlist
ION Audio Block Rocker M5 Portable Speaker AM/FM Black
ION Audio Block Rocker M5 Portable...
£207.31
£207.31
Add to wishlist
Delivery
Standard Due date unavailable
Block Rocker Bluetooth is an all-in-one wireless sound system for smartphones, tablets, microphones, and instruments. Designed to deliver powerful sound anywhere, Block Rocker Bluetooth comes equipped with a 50-Watt speaker that projects your music, loud and clear. Its wireless capability means you can keep your smartphone or tablet right by your side as you play your music from up to 100 feet away. Plus, the Easy Pair feature connects NFC-enabled smartphones with just a simple tap. Block Rocker Bluetooth provides up to 50 hours of on-the-go sound with its long-lasting rechargeable battery. A powerbank with a fast-charging USB port and the device cradle ensure your tablet or smartphone stays powered up and sits securely. For maximum portability and easy setup, Block Rocker Bluetooth features rugged wheels and a telescoping handle.
ION Block Rocker Bluetooth M5 - speaker - for portable use - wireless
Speaker - for portable use
AM/FM radio
Speaker Type
2-way - active
Max Output Power
50 Watt
Frequency Response
77 - 20000 Hz
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - mono 50 Watt - 77 - 20000 Hz - 2-way - active
Power Options
USB charging
Speaker battery rechargeable - Lead Acid
AM/FM radio
Enclosure Colour
Design Features
Phone/tablet stand design
Speaker System
Speaker Type
2-way - active
Max Output Power
50 Watt
Frequency Response
77 - 20000 Hz
Amplifier
Integrated
Bluetooth 4.0, Near Field Communication (NFC)
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Controls
Microphone volume, power on/off, volume, activate Bluetooth
Speaker System Details
Speaker Details
Driver Details
Speaker: woofer driver , Speaker: tweeter driver
Connector Type
2 x DC power output (4 pin USB Type A (power only)) , Microphone/guitar audio input (phone mono 6.3 mm) , Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, microphone, power cable
Power Source
Options
USB charging
Rechargeable - Lead Acid
Run Time (Up To)
50 hour(s)
Scroll to top
