BT.com
Wishlist
IO Gear DVI-D CAT5e/6 MiniExtender
Delivery
Standard Due date unavailable
The GVE200 DVI-D Video Extender allows you to extend the distance between the computer system unit and the display unit by up to 65 feet. It accomplishes this by means of a local transmitting unit and remote receiving unit connected by standard solid Category 5e/6 Ethernet cable. The GVE200 Video Extender System is ideal for factory and construction sites, or any installation where the display needs to reside in a harsh setting, but you want the system equipment kept in an environmentally friendly location. The Extender System is also useful for control and security purposes, where you can have the system unit in a secure area at the same time that you put the display in an area that is convenient for viewing.
IOGEAR DVI-D CAT5e/6 MiniExtender GVE200 (1 Local & 1 Remote) - video extender
Video extender
External
Max Transfer Distance
20 m
Video extender
External
Wired
Max Resolution
1920 x 1080
Max Video Bandwidth
1.65 Ghz
20 m
Status Indicators
2 x network - RJ-45 female , 2 x DVI-D male
Scroll to top
