BT.com
Wishlist
Intermec PM43 Monochrome Direct Thermal Label Printer
Intermec PM43 Monochrome Direct...
£1,060.20
24 in stock
£1,060.20
Add to wishlist
Delivery
Standard 1-3 working days
PM43 mid-range industrial label printers are ready to perform, designed to maximize your uptime. Count on PM43 to deliver quick deployment and proven reliability. Ideal for a wide range of applications within the distribution center, warehouse and manufacturing environments.
Intermec PM43 - label printer - monochrome - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
15.8 kg
Europe
Max Media Size
Roll (11.4 cm)
Min Media Size (Custom)
19.1 mm
Max Media Size (Custom)
114.3 mm
Print Speed
Up to 300 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, LAN, serial
RAM Installed (Max)
128 MB SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
ZPL, Intermec Printer Language (IPL), DSim (Datamax Interpreter), ZSim, Extensible Mark-up Language (XML), DPL
Barcodes
EAN/JAN, Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, HIBCC, LOGMARS, MicroPDF417, Codabar, Code 128, Code 11, Code 16K, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, AIAG, Standard 2 of 5, Grid Matrix Code
Media Type
Labels, linerless labels, fanfold paper, tag stock, tickets
Print server - Ethernet, Fast Ethernet
Printer Features
RFID ready, USB host
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
28.4 cm x 48.4 cm x 29.5 cm
Printer Type
Europe
Printer
Print Speed
Up to 300 mm/sec - max speed - 203 dpi
Built-in Devices
Touch screen
Wired
USB, LAN, serial
203 dpi
Language Simulation
Barcodes
Printer Features
RAM
RAM Installed (Max)
128 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
19.1 mm
114.3 mm
Media Sizes
Roll (1.9 - 11.4 cm)
Max Printing Width
108 mm
Media Weight
57.6 g/m² - 250 g/m²
Roll Maximum Outer Diameter
213 mm
Roll Core Diameter
76.2 mm, 38.1 mm
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
Print server
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, LPR/LPD, SMTP, FTP, BOOTP, DHCP
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP
1 x USB 2.0 - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45 , 1 x USB - 4 pin USB Type A
Fixed media hanger
FCC Class A certified, UL, C-Tick, cUL, EN55022, CCC, RoHS
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
300 Watt
Power Consumption Stand by / Sleep
9 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
20 - 80% (non-condensing)
28.4 cm
48.4 cm
29.5 cm
15.8 kg
Scroll to top
