BT.com
Wishlist
Intermec PC43t Mono Thermal Transfer Printer
Intermec PC43t Mono Thermal...
£379.96
£379.96
Add to wishlist
Delivery
Standard Due date unavailable
The Intermec PC43t is designed to set a new standard in user friendliness and flexibility. PC43t features an icon-graphics user interface for maximum ease of use. PC43t features low cost and fast operation which makes it a smart choice for light-duty labeling applications where users need a reliable, easy-to-use printing solution.
Intermec PC43t - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
2.7 kg
Europe
Max Media Size
Roll (11.8 cm)
Min Media Size (Custom)
19 mm
Max Media Size (Custom)
118 mm
Print Speed
Up to 203.2 mm/sec - max speed - Roll (11.8 cm)
Max Resolution (B&W)
203 dpi
USB
RAM Installed (Max)
128 MB DDR2 SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
Intermec Printer Language (IPL), EPL2, Intermec Fingerprint, Intermec ESim, DSim (Datamax Interpreter), ZSim, Extensible Mark-up Language (XML), DPL
Barcodes
UCC/EAN-128, Code 49, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, MicroPDF417, Code 16K, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, Plessey, Grid Matrix Code
Media Type
Labels, self-adhesive labels, linerless labels
Fonts
OCR-A, OCR-B
Real time clock, adjustable gap sensor
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
1 year warranty
21 cm x 28.1 cm x 22.7 cm
Printer Type
Europe
Printer
Print Speed
Up to 203.2 mm/sec - max speed - 203 dpi - Roll (11.8 cm)
Built-in Devices
Status LCD
Wired
USB
203 dpi
Language Simulation
Fonts
OCR-A, OCR-B
Barcodes
RAM
RAM Installed (Max)
128 MB
Technology / Form Factor
DDR2 SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
19 mm
118 mm
Media Sizes
Roll (11.8 cm)
Max Printing Width
104 mm
Max Printing Length
1727 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38.1 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
1 x USB cable
FCC Class A certified, UL, TUV GS, C-Tick, BSMI, cUL, GS, EN55024, CISPR 22, EN55022 Class B, CCC, EMC, IEC 60950-1, KCC, cULus
Power adapter - external
AC 120/230 V
Frequency Required
50 - 60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
1 year warranty
5 °C
10 - 80%
21 cm
28.1 cm
22.7 cm
2.7 kg
Scroll to top
