BT.com
Wishlist
Intel Solid-State Drive DC P3700 Series - 800 GB - PCI Express 3.0 x4
Delivery
Standard Due date unavailable
The Intel Solid-State Drive Data Center family for PCIe brings extreme data throughput directly to Intel Xeon processors with up to six times faster data transfer speed than 6 Gbps SAS/SATA SSDs. The performance of a single drive from the Intel SSD Data Center family for PCIe, specifically the Intel Solid-State Drive Data Center P3700 series (460K IOPS), can replace the performance of 7 SATA SSDs aggregated through a host bus adapter (HBA).
Intel Solid-State Drive DC P3700 Series - solid state drive - 800 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
800 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
6.985 cm x 10.045 cm x 1.5 cm
115 g
Microsoft Certification
Compatible with Windows 7
800 GB
2.5"
6.985 cm
10.045 cm
1.5 cm
115 g
Performance
Internal Data Rate
2.8 GBps (read) / 1.9 GBps (write)
4KB Random Read
460000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
Compatible Bay
2.5"
Power Consumption
18 Watt (write) , 9 Watt (read) , 4 Watt (idle)
Microsoft Windows Server 2012, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
70 °C
5 - 95%
Shock Tolerance
1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Scroll to top
