BT.com
Wishlist
Intel NUC5i5RYK Core i5 5250U 1.6GHz LAN WLAN BT HD Graphics 6000
Intel NUC5i5RYK Core i5 5250U...
£358.72
£358.72
Add to wishlist
Delivery
Standard 1-3 working days
A revolution in ultra-compact device design, the Intel NUC NUC5i5RYK packs more features into 4 inches square. The NUC5i5RYK is equipped with the 5th generation Intel Core i5-5250U processor with Intel Turbo Boost Technology 2.0 which gives you extra GHz on demand to let you maximize performance on processor-intensive tasks like media editing. A replaceable lid gives you plenty of options to create the NUC you want - with amazing style and features. It also features Intel HD Graphics 6000 with 4K display capabilities to provide visually stunning graphics. A high-speed USB 3.0 charging port lets you easily charge your tablet or smartphone quickly. Complete with WiFi 802.11ac wireless, Bluetooth, and 7.1 surround sound, the Intel NUC NUC5i5RYK is ideal for home theater PCs, media server PCs, and home hubs. For peace of mind, you'll get embedded security that helps keep threats out and user identities and credentials safe. With this kind of power, size, and versatility, you'll rethink what's possible.
Intel Next Unit of Computing Kit NUC5i5RYK - mini PC - Core i5 5250U 1.6 GHz - 0 MB - 0 GB
PC barebone - mini PC
1 x Intel Core i5 (5th Gen) 5250U / 1.6 GHz (2.7 GHz) (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel 64 Technology
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 MB (installed) / 16 GB (max) - DDR3L SDRAM
Hard Drive
No HDD
Graphics Controller
Audio Output
7.1 channel surround - integrated
GigE, 802.11b, 802.11a, 802.11g, 802.11n, Bluetooth 4.0, 802.11ac
OS Provided
No operating system
11.5 cm x 11.1 cm x 3.45 cm
3 years warranty
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Silver with black top and diamond cut around the top
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 MB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Dual channel memory architecture
Hard Drive
No HDD
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
ACPI support, Intel Wireless Display (WiDi)
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x M.2 Card
4 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x SATA-600 (2 internal)
VESA mounting kit
Voltage monitoring, temperature sensor, Intel Rapid Start Technology, 1 USB 3.0 charging port, Intel Ready Mode Technology
Theft/Intrusion Protection
EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, ACPI 3.0b, CAN/CSA C22.2 No. 60950-1, VCCI V-3, Directive 2002/96/EC, VCCI V-4, KN22, KN24, China RoHS, Directive 2011/65/UE
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
No operating system
Limited warranty - replacement - 3 years
11.5 cm
11.1 cm
3.45 cm
50 °C
Accessories
£6.91
£6.55
£20.79
C2G 2m Mini DisplayPort Cable M/M - White
Quicklinx: 9MSD | In Stock
£11.01
C2G HDMI Mini to HDMI Adapter Converter
Quicklinx: 9WD1 | In Stock
£8.37
Scroll to top
