BT.com
Wishlist
Intel NUC Celeron 847 QS77 DDR3 USB 2.0 2 x HDMI (Next Unit of Computing)
Delivery
Standard Due date unavailable
The Next Unit of Computing (NUC) Kit DCCP847DYE delivers new levels of performance and responsiveness in a pocket-sized solution. With an Intel Celeron processor, the NUC is an affordable, customizable computing system that fits in the palm of your hand and offers a world of flexibility.
This fully scalable, next generation computing device provides a flexible, customizable engine. Create a PC home system to experience your movies and photos or drive digital signage such as menus, news and weather. The NUC challenges you to rethink what's possible. Because the only thing more amazing than Intel technology is what you'll do with it.
The Intel® NUC family puts the world in the palm of your hand. Powered by either Intel® Celeron® processors or 3rd generation Intel® Core™ processors on a four-by-four-inch motherboard and enclosed in a tiny case, this next-generation compute kit is big on performance yet surprisingly small in size. From digital signage to customer service kiosks, from home theater systems to digital jukeboxes, Intel® NUC is an intelligent device for small spaces or anywhere else you can imagine. A revolution in ultra-compact device design, Intel® NUC packages a fully scalable, computing solution in the smallest possible form factor, complete with the Intel® Core™ i5 vPro™ processor. This new generation computing device provides a flexible, customizable engine to drive digital signage, kiosks, and intelligent computing for small spaces, or anywhere else you can imagine. Intel® NUC also has triple display capabilities for multiple monitoring and display, along with Intel® vPro™ technology which lets your IT service provider remotely manage or repair your system. With that kind of power and size, you'll rethink what's possible. Because the only thing more amazing than Intel® technology is what you'll do with it.
  • Type : PC barebone
  • Product Form Factor : Ultra compact form factor
  • CPU : Intel Celeron 847 / 1.1 GHz
  • Number of Cores : Dual-Core
  • CPU Qty : 1
  • Chipset: Intel QS77 Express Chipset
  • Graphics: Intel HD Graphics with Dual HDMI Ports supporting Dual Independent Display Capability
  • Peripheral Connectivity: Integrated Intel Gigabit Network Connection, Three Hi-Speed USB 2.0 Ports.
  • Expansion Capabilities: One full length mini-PCIe slot supporting mSATA capability and one half length mini-PCIe slot with dual USB 2.0 ports routed
Box Contents
  • Intel NUC
  • Power brick
  • VESA Mounting bracket
  • Intel Core i3 sticker
  • Wifi antennae
  • Please note you will need to purchase an A/C Power Cord
Intel Next Unit of Computing Kit DCCP847DYE - Celeron 847 1.1 GHz - 0 MB - 0 GB
PC barebone - ultra compact form factor
1 x Intel Celeron 847 / 1.1 GHz (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
0 MB (installed) / 16 GB (max) - DDR3 SDRAM
Hard Drive
No HDD
Graphics Controller
Intel HD Graphics
Audio Output
7.1 channel surround - integrated
GigE
OS Provided
No operating system
11.66 cm x 11.2 cm x 3.9 cm
3 years warranty
PC barebone
Product Form Factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Chipset Type
Mobile Intel QS77 Express
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
0 MB / 16 GB (max)
DDR3 SDRAM
SO-DIMM 204-pin
Unbuffered, dual channel memory architecture
Hard Drive
No HDD
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
ACPI support
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x Mini PCIe - full-length , 1 (total) / 1 (free) x Mini PCIe - half-length
3 x USB 2.0 (1 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x HDMI
VESA mounting kit
Voltage monitoring, temperature sensor, automatic fan speed control
Theft/Intrusion Protection
CISPR 24, EN 61000-3-2, EN55022, ICES-003, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC CFR47 Part 15 B, GOST-R, CSA C22.2 No. 60950-1, VCCI V-3, EMC Class B, NOM-019-SCFI-1998
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
No operating system
Limited warranty - 3 years
11.66 cm
11.2 cm
3.9 cm
55 °C
Accessories
£7.58
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.40
£41.56
£56.34
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great little machine
Reviewed by Dan on 07/08/2013
If you know how to set up its a great little machine, im using it for XBMC running openelec from a usb thumb drive (dont need to buy an mSATA if you do this) 2GB RAM and it runs fine, lovely and smooth, has no problems with HD playback even The Birds (http://goo.gl/b6mPT) runs cool and quiet, can only really hear the fan if you are right next to it in a dead quiet room! If you are planning on running from USB use a USB3.0 stick, i know the ports are USB 2 but USB 3 sticks are generally faster and will hopefully max out the USB2 port speed! One thing id say is make sure you know what you need: RAM mSATA if planning on running windows a 3 pin power lead! it comes with the power brick but not the lead to plug into the mains and its not clear on the advert here that this isnt included, my only gripe... so basically a fantastic very good little machine for media playback!
4* Not bad at all.
Reviewed by Doug on 30/06/2013
Quiet, quick and cool. It will do 1080p, but it struggles with some codecs so if you want it for a HTPC I'd get an i3 version. For every day computing though its excellent. Fast browsing, fast opening apps and overall very snappy. It's well built and very small. I like it a lot. I've tried it with Win 8, Win 7 and Ubuntu 12.04 and it ran all 3 with no problem. I'm writing this review on it.
Scroll to top
