BT.com
Wishlist
Intel DZ77RE-75K S1155 Intel Z77 DDR3 ATX
Delivery
Standard 1-3 working days
Introducing the Intel® Desktop Board DZ77RE-75K. Intel's®™ first Desktop Board with Thunderbolt Technology. Also optimized for Intell® -K processors to maximize your overclocking performance!
The boxed intel® Desktop board DZ77RE-75K Solution includes
  • Intel® Desktop Board DZ77RE-75K
  • ATX 2.2 compliant I / O shield
  • UV reactive SATA cables
  • Extreme mouse pad
  • Bluetooth/ Wi-Fi module
  • Front Panel USB
  • Board and back panel I / O layout stickers
  • Quick reference guide
  • Intel® Express Installer driver and software DVD
  • Windows Premium WHQL certified
  • NVIDIA SLI Bridge connectors
  • Post code inform
Intel Desktop Board DZ77RE-75K - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 1 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 1 x FireWire + 4 x USB 2.0 + ( 4 x USB 3.0 + 1 x FireWire + 4 x USB 2.0 via headers )
Audio
HD Audio (10-channel)
LAN
2 x Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 1900 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1200 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2100 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC898
High Definition Audio
LAN
Network Controller
Intel 82574L / Intel 82579
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 2 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
RAID Features
Intel Rapid Storage Technology
1 x HDMI , 1 x FireWire - 6 pin FireWire , 4 x USB 2.0 , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out/microphone - mini-jack , 1 x PS/2 keyboard / mouse , 1 x - Thunderbolt
Internal Interfaces
4 x USB 2.0 , 1 x FireWire , 4 x USB 3.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
Intel
BIOS Features
ACPI support, DMI support, SMBIOS support, Hyper-Threading Technology, Wfm support
Sleep / Wake Up
RTC (real-time clock) wake up, suspend to RAM (STR), wake on LAN (WOL), wake on PCI device, wake on USB port, wake on infrared
Hardware Features
Chassis intrusion detection, Intel Active Management Technology (Intel AMT)
C-Tick, BSMI, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1, VCCI V-3
30.5 cm
24.4 cm
Package Type
Retail
Limited warranty - 3 years
Scroll to top
