BT.com
Wishlist
Intel DX79TO Extreme Series Motherboard ATX LGA2011
Delivery
Standard Due date unavailable
Need a machine that can handle your complex workload? The DX79TO is the machine for you. Whether rendering, doing animations, gaming, or crunching data, today's power user needs a computing platform that delivers maximum multi-threaded CPU support. The Intel Desktop Board DX79TO is designed to provide the power you need. The massive data throughput and support for the Intel Core i7 processor Extreme Edition runs more applications simultaneously, with less wait time. Not only fast but secure, the Intel Trusted Platform Module (Intel TPM) provides extra platform integrity and security. SuperSpeed USB 3.0, SATA 6.0 Gb/s, quad channel DDR3 memory, and full support for AMD CrossfireX and NVIDIA SLI technology are just a few of the many features supported on this board.
Intel Desktop Board DX79TO - Extreme Series - motherboard - ATX - LGA2011 Socket - X79
Motherboard - ATX
Chipset Type
Intel X79 Express
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Core i7 (does not support 4th Generation Intel CPUs)
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR3, non-ECC, ECC
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 + (1 x FireWire + 8 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Motherboard - ATX
Chipset Type
Intel X79 Express
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Quad channel memory architecture
Audio
Audio Codec
Realtek ALC892
LAN
Network Controller
Intel 82579L
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 8 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 2 x PCIe x1 , 1 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x audio line-out/line-in - mini-jack , 1 x microphone - mini-jack , 2 x USB 3.0 , 1 x FireWire - 6 pin FireWire
Internal Interfaces
1 x FireWire , 8 x USB 2.0
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
Intel
BIOS Features
ACPI support, rapid BIOS boot, SMBIOS support, Hyper-Threading Technology
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Sleep / Wake Up
RTC (real-time clock) wake up, suspend to RAM (STR), wake on LAN (WOL), wake on PCI device, wake on USB port
Hardware Features
Chassis intrusion detection, Intel Fast Memory Access Technology, Intel Turbo Boost Technology
Software Included
Drivers & Utilities
Plug and Play, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, EMC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1, VCCI V-3
29.5 cm
24.4 cm
Package Type
Retail
ENERGY STAR Certified
Limited warranty - 3 years
Scroll to top
