BT.com
Wishlist
Intel Core i5-4690K 3.50GHz 6MB S1150 Quad Core 'Devils Canyon' Processor with Heat Sink Fan
Intel Core i5-4690K 3.50GHz 6MB...
Free delivery
£234.99
Free delivery
40 in stock
£234.99
Add to wishlist
Delivery
Standard 1-3 working days
Looking for the perfect processor to build your gaming rig around? But you also want to edit your action videos and photos? But to do this you know you need serious performance. Not to worry - Intel is happy to anounce our first 4GHz base frequency quad core processor. If it is performance you crave, then this is the processor you have been waiting for. But what if you feel the neeed to overclock your system to squeeze every last bit of performance out of it? Well, then this is still the processor for you. The Latest Intel Core i5 and i7 processors, paired with the latest Intel 9 series H and Z chipsets, will get you the results you want. Add in features like built in visuals and Intel Quick Sync Video, which allows the conversion of media from one device to another and prepares your media to share online at incredible speeds, and these are processors that meet every need you have.
Intel Turbo Boost Technology
Dynamically increases the processor's frequency as needed by taking advantage of thermal and power headroom when operating below specified limits.
Technology Built-In Visuals
- Intel HD Graphics - Enhanced 3D performance for immersive mainstream and casual gaming. can support up to three UltraHD (4K) displays and collage display.
- Intel Wireless Display - Wirelessly stream HD / 3D video and games to your TV or projector for presentations and entertainment.
- Intel Quick Sync Video - Delivers fast conversion of video for portable media players, online sharing and video editing and authoring
- Intel Clear Video HD - Visual qulity and colour fidelity enhancements for HD playback and immersive Web browsing.
- Intel InTru 3D - Stereoscopic 3D Blu-ray playback in full 1080p resolution over HDMI 1.4 and premium audio.
- Intel Advanced Vector Extensions - A set of new instrutions to improve software performance for floating point-intensive applications such as audio processing, audio codecs, and image and video editing applications.
Integratied Memory Controller
An integrated memory controller offers stunning memory read/write performance through efficient prefetching algorithms, lower latency, improving performance.
Intel Virtualization Technology
Allows one hardware platform to funtion as multiple "virtual" platforms by isolating computing activities into separate partitions.
Advanced Encryption Standard New Instructions
New AES instructions add hardware acceleration to AES algorithms and speeds up the execution of AES applications.
Thermal Solution for Boxed Processors
Includes a four-pin connector for fan speed control to help minmize the acoustic noise levels generated from running the fan at higher speeds for thermal performance.
Intel Core i5-4690K 3.50GHz 6MB S1150 Quad Core 'Devils...
£234.99
Save on this ideal PC Build kit!
Save £10.36
£254.54
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent processor, great for gaming
Reviewed by Carl Worthintgon on 17/10/2014
The CPU is great from the get-go, very easy to overclock when the necessary motherboard.
No problems with installation.
A little pricey but the 4690k is a better pick over the slightly cheaper 4670k for it's improved clockability and better thermal trim.
5* Works like a charm!
Reviewed by Asad on 03/07/2015
Worth the money if you're going for a high-end computing rig.
I've used ASUS Suite 3 and the ASUS BIOS to overclock this beauty to 4.9GHz, obviously I won't run it at that speed as my computer will fry.
My setup is:
i5 4690K @ 3.5GHz
ASUS Z97-A
16GB Crucial Tactical Tracers @ 1600MHz (DDR3)
H80i (Corsair Watercooler)
600W Corsair Modular PSU
R9 280 Sapphire DUAL-OC X
Games such as GTA V run constantly at 60FPS on my 1080p monitor. There are some hiccups but that's due to the game itself having a bit of hicks towards my GPU.
1* stock cooler
Reviewed by Gerard on 16/01/2015
The stock cooler is intermitting at start up. Not sure if it’s the wiring or motor am just going to replace it with a Hyper 212 EVO to tie me over
Scroll to top
