BT.com
Wishlist
Intel 480GB S3500 Series 2.5" SATA 6Gb/s Solid State Drive
Delivery
Standard Due date unavailable
The Intel SSD DC S3500 Series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9% of the time) along with a tight distribution of up to 75,000 input/output per second (IOPS) delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
Intel Solid-State Drive DC S3500 Series - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
End-to-end data protection (ANSI), SMART Command Transport (SCT), Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, S.M.A.R.T., 256-bit AES
69.85 mm x 100.45 mm x 7 mm
72 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
480 GB
2.5"
SATA 6Gb/s
69.85 mm
100.45 mm
7 mm
72 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 410 MBps (write)
4KB Random Read
75000 IOPS
4KB Random Write
11000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s - 22 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
4.3 Watt (active) , 0.9 Watt (idle)
UL, VCCI, C-Tick, BSMI, RoHS, KCC
Limited warranty - 5 years
70 °C
5 - 95%
Shock Tolerance
1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Scroll to top
