BT.com
Wishlist
Intel 240GB S3500 Series 2.5" SATA 6Gb/s Solid State Drive
Intel 240GB S3500 Series 2.5" SATA...
£221.83
£221.83
Add to wishlist
Delivery
Standard Due date unavailable
The Intel SSD DC S3500 Series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9% of the time) along with a tight distribution of up to 75,000 input/output per second (IOPS) delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
Intel Solid-State Drive DC S3500 Series - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), End-to-end data protection (ANSI), SMART Command Transport (SCT), Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, S.M.A.R.T., 256-bit AES
60.95 mm x 100.45 mm x 7 mm
70 g
Microsoft Certification
Compatible with Windows 7
5 years warranty
240 GB
2.5"
SATA 6Gb/s
60.95 mm
100.45 mm
7 mm
70 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 260 MBps (write)
4KB Random Read
75000 IOPS
4KB Random Write
7500 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.1 Watt (active) , 0.9 Watt (idle)
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, CISPR 22, FCC Part 15 B, RoHS, UL 60950-1 Second Edition, KCC, EN 60950-1 Second Edition
Package Type
OEM
Limited warranty - 5 years
70 °C
5 - 95%
Shock Tolerance
1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Other bundles
Intel 240GB S3500 Series 2.5" SATA 6Gb/s Solid State...
£221.83
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.24
£225.07
Scroll to top
