Intel 180GB 330 Series MLC 2.5" 25nm SATA 6GB/s 9.5mm SSD
Standard Due date unavailable
The perfect blend of cutting edge performance, Intel quality, and value.
Ideal for price-conscious enthusiasts looking to upgrade a desktop or notebook PC, the Intel® SSD 330 Series brings SATA 6Gb/s transfer rates to the Intel® Solid-State Drive 300 Family. Offered in the most popular capacities (60GB, 120GB and 180GB), the Intel® SSD 330 Series boosts overall system performance and responsiveness for a broad range of applications.
Technology and Performance.
The SATA 6Gb/s interface doubles the data transfer rate from its SATA 3Gb/s predecessor, powering the Intel® SSD 330 Series to blazing fast sequential reads up to 500MB/s to handle your most demanding applications with ease. The end result: a vastly more responsive PC with quick operating system (OS) boot and application load times, significantly out-performing a typical consumer hard disk drive (HDD).
Quality and Reliability You Can Trust.
The Intel® SSD 330 Series is backed by a 3-year limited warranty and based on 25nm Multi-Level Cell (MLC) Intel® NAND Flash Memory and validated for three years of worry-free useful life. Intel® SSD 330 Series delivers the world class quality, reliability, and customer support you've come to expect from Intel.
  • SATA 6Gb/s, compatible with SATA 3Gb/s
  • 2.5 inch (9.5 mm thick)
  • 3-year limited warranty
  • Includes 2.5" to 3.5" drive adapter and SATA cables
  • Capacity: 180GB
  • Sequential Read/Write (up to): 500 MB/s / 450 MB/s
  • Random 4KB Read/Write (up to): 42,000 IOPS / 52,000 IOPS
  • Interface: SATA 6Gb/s, compatible with SATA 3Gb/s
  • Form Factor: 2.5 inch (9.5 mm thick)
Intel Solid-State Drive 330 Series - solid state drive - 180 GB - SATA 6Gb/s
Solid state drive - internal
180 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" (in 3.5" carrier)
SATA 6Gb/s
Native Command Queuing (NCQ) , S.M.A.R.T.
70 mm x 100 mm x 9.5 mm
80 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
180 GB
SATA 6Gb/s
70 mm
100 mm
9.5 mm
80 g
Internal Data Rate
500 MBps (read) / 450 MBps (write)
4KB Random Read
42000 IOPS
4KB Random Write
52000 IOPS
1,200,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" or 3.5" (with included bay adapter)
3.5-inch bay adapter
1 x Serial ATA cable
Mounting Kit
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition
Package Type
Limited warranty - 3 years
70 °C
5 - 95%
Shock Tolerance
1500 g @ 0.5ms (operating) / 1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Nvidia motherboard owners beware
Reviewed by Andrew H on 01/12/2012
Rather than build a whole new PC I decided to give my current one a bit of a boost with an SSD.
The kit contains all the hardware you'll need for a desktop installation although you need to download the Intel Toolbox and data migration tool.
I noticed straight away a significant improvement in boot times and general snappiness compared to the old hard drive.
I then found I couldn't use the Intel SSD Toolbox because it gave an error message about being unable to communicate with the drive. I tried updating my SATA controller drivers at which point I noticed the drive was running at SATA I 1.5Gbps transfer rate despite my motherboard being capable of 3Gbps. It turns out this is a widespread problem between some SSDs and NVidia nForce SATA controllers, even with the latest drivers.
It looks like I won't realise the full potential of this drive in my current setup but it still makes things much faster.
Scroll to top
