BT.com
Wishlist
Intel 160GB X25-M SATAII 2.5" MLC
Delivery
Standard Due date unavailable
Intel high performance Solid-State Drives (Intel SSDs) are designed to deliver outstanding performance and reliability. With no moving parts, Intel SSDs offer a quiet storage solution that responds quickly and uses less power. Compared to traditional hard disk drives, Intel SSDs are significantly more responsive, much more reliable, have lower power consumption and are completely quiet.
Intel SSDs are designed and validated specifically for PC applications using Intel's deep knowledge and understanding of PC design.
Intel X25-M Mainstream - 34nm Product Line - solid state drive - 160 GB - SATA 3Gb/s
Solid state drive - internal
160 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 3Gb/s
Native Command Queuing (NCQ) , S.M.A.R.T.
70 mm x 100 mm x 9.5 mm
80 g
3 years warranty
160 GB
2.5" x 1/8H
SATA 3Gb/s
70 mm
100 mm
9.5 mm
80 g
Performance
Internal Data Rate
250 MBps (read) / 100 MBps (write)
Reliability
MTBF
1,200,000 hours
Expansion & Connectivity
1 x SATA 3 Gb/s
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
3.5-inch bay adapter
Mounting Kit
Included
UL, VCCI, C-Tick, BSMI, WHQL, MIC, RoHS
Package Type
Retail
Limited warranty - 3 years
70 °C
5 - 95%
Shock Tolerance
1500 g @ 0.5ms (operating) / 1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-800 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* X25-M SATA II 160gb SSD by Intel.
Reviewed by Jace on 06/06/2010
To be honest I was a little dubious of buying such an expensive drive. I had a WD Velociraptor Drive in before, and (anyone who knows about them) they are the fastest HDD's on the market with a spin of 10,000 rpm - as far as I know there's only two manufacturers that make this speed HDD for mainstream use. I choose to do a full and complete fresh install, rather than using Ghost or similar. We'll that's where the speed was instantly noticed. To fresh install Windows 7 64-bit took around 7-8 mins! When it was all installed it took longer to go through the bios than to load Windows! Even now, with everything loaded, i.e. Norton 360, etc (and all the usual stuff that slows the whole re-boot procedure down), it cold boots in around 25 seconds!
As a summary, this is probably one of the most significant upgrades you can do - not cheap, but well worth the money!
Scroll to top
