BT.com
Wishlist
Intel 160GB 320 Series MLC 2.5" 25nm SATA-300 9.5mm SSD
Delivery
Standard Due date unavailable
The fast hard drive alternative
Intel® Solid-State Drives (Intel® SSDs) just got better. The next generation Intel SSD 320 Series offers built-in data protection features, better performance, larger capacities and more value for your money.
Experience a new level of PC responsiveness and data protection with the Intel® Solid-State Drive 320 Series.
  • More responsive than traditional hard drives for a better overall PC experience.
  • No moving parts reduces the risk of data loss in case of bumps or drops.
  • The quality and reliability you expect from Intel, the leading manufacturer of PC processor technology.
  • Based on innovative, industry-leading 25nm Flash technology.
  • Consumes less power than a traditional hard drive so you can stay mobile longer.
The Intel® Solid-State Drive, 320 Series, was created to tackle the most demanding applications your netbook or notebook PC has to offer, at a significant value for solid-state computing.
Built with 25 nanometer (nm) compute-quality Intel® NAND Flash Memory, the Intel SSD 320 Series accelerates PC performance where it matters most.
The new Intel SSD 320 Series contains built-in features to help protect your data from external threats and internal system snags.
The Intel SSD 320 Series comes pre-configured with Advanced Encryption Standard (AES) 128 bit encryption capabilities2. In the event of theft or loss of your computer, you have the peace of mind that your personal data is secured by an advanced encryption technologies. Additionally, two new data protection features guard your data from internal system mishaps. To reduce potential data loss, the Intel SSD 320 Series detects and protects from an unexpected system power loss. The drive saves all cached data in the process of being written before shutting down, thereby minimizing potential data loss.
The Intel SSD 320 Series also improves reliability by providing an array of surplus NAND flash. If the controller encounters a faulty NAND array, the Intel SSD 320 Series automatically reconfigures itself to reduce the prospect of data loss.
Available in a wide range of capacities, the Intel SSD 320 Series provides you with the flexibility to choose an SSD that best fits your need and budget.
Intel ® 320 Series High Performance SATA 160 GB SSD
Technical Details
  • SATA 3Gb/s, compatible with SATA 1.5Gb/s
  • 2.5 inch Industry Standard Form Factor
  • Height: 7.00 mm thick
  • Weight: 82 grams (± 2 grams)
  • Operating Temperature 0°C to 70°C
Bandwidth
  • Sustained Sequential Reads (up to) 270 MB/s
  • Sustained Sequential Writes (up to) 165 MB/s
Random I/O Operations per Second
  • Random 4KB Reads: Up to 39,000 IOPS
  • Random 4KB Writes Up to 21,000 IOPS
  • Service and Support 3 Years Warranty
Reliability / Life Expectancy
  • 1.2 million hours Mean Time Between Failures (MTBF)
Box Contains
  • Intel® Solid-State Drive, 320 Series, 160GB SSD
  • Mini CD-ROM with Warranty Documentation and Installation Guide
  • Speed Demon sticker
  • Quick install guide instructions
  • Desktop Install Kit: 3.5 Inch bracket, screws + SATA signal Cable + SATA Power Cable
Intel Solid-State Drive 320 Series - solid state drive - 160 GB - SATA 3Gb/s
Solid state drive - internal
160 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 3Gb/s
Native Command Queuing (NCQ), S.M.A.R.T., 128-bit AES
70 mm x 100 mm x 9.5 mm
88 g
Microsoft Certification
Compatible with Windows 7
160 GB
2.5" x 1/8H
SATA 3Gb/s
70 mm
100 mm
9.5 mm
88 g
Performance
Internal Data Rate
270 MBps (read) / 165 MBps (write)
4KB Random Read
39000 IOPS
4KB Random Write
21000 IOPS
Average Latency
0.075 ms
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
3.5-inch bay adapter
1 x Serial ATA cable
Mounting Kit
Included
UL, VCCI, C-Tick, BSMI, WHQL, RoHS, KCC
70 °C
5 - 95%
Shock Tolerance
1500 g @ 0.5ms (operating) / 1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
Scroll to top
