BT.com
Wishlist
Infocus IN126STa 1280x800 3300 lumens WXGA DLP Projector
Infocus IN126STa 1280x800 3300...
£737.67
£737.67
Add to wishlist
Delivery
Standard Due date unavailable
The InFocus IN120STa Series projectors combine short throw, high brightness, networking and low cost - making them perfect for classrooms, offices, or tight spaces like trade show booths. These value-packed projectors are easy to buy and built to perform with multiple ways to connect, beautiful image quality, and option to convert to an interactive projector. Plus, the short throw lens reduces shadows, prevents light from shining in the presenter's face, and saves space.
InFocus IN126STA DLP projector - 3D
DLP projector - High Definition 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3300 lumens
Contrast Ratio
15000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 7000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
29.2 cm x 22 cm x 10.8 cm
3.2 kg
1 year warranty
DLP projector - HD 720p
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3300 lumens
Brightness (Reduced)
3000 lumens
Contrast Ratio
15000:1
Throw Ratio
0.48:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
Eco-Mode technology, 6-segment colour wheel, JPEG photo playback, MP3 playback, built-in 2 GB flash memory, DLP 3D Ready, 16:9 aspect ratio support, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, 4:3 aspect ratio support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Digital Video Format
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x network - RJ-45
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), PIN code, security bar
UL, cUL, FCC
29.2 cm
22 cm
10.8 cm
3.2 kg
Limited warranty - 1 year , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
32 dB
30 dB
Accessories
£9.99
£5.98
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.99
£39.99
£54.98
£17.48
Scroll to top
