BT.com
Wishlist
Infocus IN112x 800x600 3200 lumens  SVGA 3D LED Projector
Infocus IN112x 800x600 3200 lumens...
£310.15
£310.15
Add to wishlist
Delivery
Standard Due date unavailable
Confidently beam your most important content with the high brightness and quality of the incredibly affordable IN112x projector.
It is built to perform with HDMI input, high brightness, high contrast, and BrilliantColor technology. Plus, its compact design makes it easy to move or install.
InFocus IN112x DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3200 lumens
Contrast Ratio
15000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
203 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
29.2 cm x 22 cm x 12.1 cm
2.45 kg
2 years warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3200 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
15000:1
Image Size
759 cm
Projection Distance
1 m - 10 m
Throw Ratio
1.9 - 2.09:1
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
203 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
6-segment colour wheel, Closed Caption, BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Eco Blank
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B (management) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), PIN code, security bar
UL, cUL, NOM, PCT, SABS, SASO, CB, CCC, PSB, FCC, IRAM, KCC, KC, CECP, EAC
Power Source
AC
29.2 cm
22 cm
12.1 cm
2.45 kg
Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
32 dB
30 dB
Accessories
£9.99
£5.98
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.99
£39.99
£54.98
£17.48
Scroll to top
