BT.com
Wishlist
iiyama XUB2490HS-B1 24" 1920x1080 HDMI IPS Monitor
Delivery
Standard Due date unavailable
Marketing description is not available.
Iiyama ProLite XUB2490HS-B1 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.9 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, pivot (rotation)
Matte black
54 cm x 23 cm x 36.5 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
VESA DPMS, TUV Bauart, TCO Displays 6.0, VCCI Class B
Display Type
Energy Class
Class A
32 kWh
21.9 W
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Slim bezel design
Matte black
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D , HDMI , Audio line-in
Mechanical
Rotation Angle
90
Height Adjustment
130 mm
1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x audio cable
22 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Accessories
£9.99
£7.15
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.01
£51.46
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£58.40
£17.48
Scroll to top
