BT.com
Wishlist
iiyama Touch Stand Compatible With: TF3237MSC-B1AG TF4237MSC
Delivery
Standard Due date unavailable
Specifically developed for touch screens which can be used in the face-up (table) position. This wheeled stand has electrical height adjustment from 660-1320 mm (table height). The Tip & Touch stand is available with a tip function by gas spring or a electrical tip function. Furthermore the head of the stand contains a fixed bracket with most VESA-patterns integrated.
Iiyama Tip & Touch - stand
Stand
Adjustable Height
66-132 cm
Recommended Use
LCD display
Flat Panel Mount Interface
950 x 590 mm
Max Load Weight
60 kg
ProLite TF3237MSC-B1AG, TF3238MSC-B1AG, TF4237MSC-B1AG, TF4338MSC-B1AG, TF4637MSC-B1AG, TF5537MSC-B1AG
Adjustable Height
66-132 cm
AV Furniture
Stand
Recommended Use
LCD display
950 x 590 mm
Max Load Weight
60 kg
Wheels, motorised, table function, electric height adjustment
Iiyama ProLite TF3237MSC-B1AG, TF3238MSC-B1AG, TF4237MSC-B1AG, TF4338MSC-B1AG, TF4637MSC-B1AG, TF5537MSC-B1AG
Scroll to top
