BT.com
Wishlist
iiyama TF3237MSC-W3AG 32" 1920x1080 DVI VGA Large Format Display
iiyama TF3237MSC-W3AG 32" 1920x1080...
£1,263.33
£1,263.33
Add to wishlist
Delivery
Standard 1-3 working days
With Full HD resolution and Projective Capacitive 12-point touch technology, the ProLite delivers seamless and accurate touch response. Featuring an AMVA3 edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands drops, making it suitable for demanding environments, like table top integration. The open frame ProLite is the ideal solution for interactive digital signage, instore retail, kiosks and interactive presentations.
Iiyama ProLite TF3237MSC-W3AG 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
White
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
48 Watt
78.15 cm x 6.9 cm x 47.6 cm
17.3 kg
Energy Class
Class B
48 Watt
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, Face-up Mode
Design
Metal frame
78.15 cm
6.9 cm
47.6 cm
17.3 kg
Enclosure Colour
White
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 6H Hard
Image Contrast Ratio
3000:1
Brightness
420 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Connector Type
DVI-D input , VGA input , Audio line-in , HDMI input , Serial , USB
Batteries, IR extension cable, cable clamp
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1, CU
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
0 - 85% (non-condensing)
Scroll to top
