BT.com
Wishlist
iiyama TF3237MSC-B3AG 32" 1920x1080 DVI VGA Large Format Display
iiyama TF3237MSC-B3AG 32" 1920x1080...
£1,250.82
£1,250.82
Add to wishlist
Delivery
Standard Due date unavailable
With 1920 x 1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF3237MSC-B3AG delivers seamless and accurate touch response. Featuring an AMVA3 Edge LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel and the panel withstands the 60950-1 ball drop test, making it suitable for demanding environments like table top integration. The open frame ProLite TF3237MSC-B3AG is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks and Interactive Presentations.
Iiyama ProLite TF3237MSC-B3AG 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
48 Watt
Power Consumption (On mode)
54.2 W
Energy Consumption per Year
79 kWh
78.15 cm x 6.9 cm x 47.6 cm
17.3 kg
Energy Class
Class B
48 Watt
54.2 W
79 kWh
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode, Face-up Mode
78.15 cm
6.9 cm
47.6 cm
17.3 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 6H Hard, glass coating
Image Contrast Ratio
3000:1
Brightness
500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Multitouch, Palm Rejection, Projected Capacitive Touch (PCT)
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - built-in - 7 Watt
Connector Type
DVI-D input , VGA input , Audio line-in , HDMI input , Serial , USB
Clamper
VGA cable , DVI cable , USB cable , IR extender cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Scroll to top
