BT.com
Wishlist
iiyama T3234MCS-B3X 32" 1920x1080 DVI VGA Touch LED LFD
iiyama T3234MCS-B3X 32" 1920x1080...
£1,497.03
£1,497.03
Add to wishlist
Delivery
Standard Due date unavailable
With 1920x1080 Full HD resolution and Projective Capacitive 30 point touch technology, the ProLite T3234MSC-B3X delivers seamless and accurate touch response. Featuring an AMVA PID grade LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with a rugged bezel making it suitable for demanding environments. The screen features a vast array of inputs including DVI as well as USB for the Touch sensor itself. The ProLite T3234MSC-B3X is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
Iiyama ProLite T3234MSC-B3X 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
PC Interface
DVI, VGA (HD-15)
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
65 Watt
78.15 cm x 6.95 cm x 47.65 cm
16.2 kg
65 Watt
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
PC Interface
DVI, VGA (HD-15)
78.15 cm
6.95 cm
47.65 cm
16.2 kg
Enclosure Colour
Display
LCD Display Technology
AMVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
405 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.364 x 0.364mm
Response Time
6.5 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Colour Temperature Control
Multitouch
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x speaker - built-in - 8 Watt
Connector Type
VGA input , DVI-D input , Serial output , USB , Serial input , Audio line-in , Audio line-out , Remote control
VGA cable , DVI cable , Audio cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Nominal Voltage
Power Consumption Stand by
2 Watt
On / Off Switch
No
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.05
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.59
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
