BT.com
Wishlist
iiyama ProLite XB2783HSU 27" 1920x1080 4ms VGA DVI DisplayPort LED Monitor
iiyama ProLite XB2783HSU 27"...
£216.00
£216.00
Add to wishlist
Delivery
Standard Due date unavailable
ProLite XB2783HSU - a 27" LED backlit LCD Screen featuring AMVA+ panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 24 bit ‘True Color’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite XB2783HSU will provide excellent performance for Photographic, Design and Web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
Iiyama ProLite XB2783HSU-B1DP - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
USB 2.0 hub
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
62.25 cm x 23 cm x 40.05 cm
6 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, TCO Displays 6.0, VCCI Class B
Display Type
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, TrueColor, Advanced Contrast Ratio (ACR), Flicker Free technology
6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , Headphones , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable , 1 x audio cable , 1 x USB cable
Power Supply
Internal
33 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
ENERGY STAR Certified
Other bundles
iiyama ProLite XB2783HSU 27" 1920x1080 4ms VGA DVI...
£216.00
Wireless keyboard and mouse set
£265.99
£216.00
Keep your electronic devices protected
£235.99
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
