BT.com
Wishlist
iiyama ProLite XB2776QS-B1 27" 2560x1440 5ms VGA DVI-D DP HDMI Black Monitor with Speakers
Delivery
Standard Due date unavailable
The XB2776QS is not just a large monitor. This LCD with LED-backlit display features a massive QHD 2560 x 1440 resolution with IPS technology. Due to these outstanding features it offers a very high performance with accurate and consistent color reproduction, color fidelity, contrast and fast response time. An array of inputs including HDMI, DisplayPort, DVI and VGA connections ensure compatibility across a range of devices. The XB2776QS comes with a Height Adjustable stand and is able to pivot, a function that is made even more effective by the wide viewing angles of 178°/178° and almost no off-angle color shift.
Iiyama ProLite XB2776QS-1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
64.4 cm x 24.95 cm x 45.5 cm
8.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, TCO Displays 6.0, VCCI Class B
Display Type
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Russian, Spanish, Dutch, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
8.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , HDMI , Audio line-in , Headphones , DisplayPort
Mechanical
Tilt Angle
-4/+24
Swivel Angle
340
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable , 1 x audio cable
Power Supply
Internal
43 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
Scroll to top
