BT.com
Wishlist
iiyama ProLite XB2485WSU-B1 24.1" 1920x1200 5m VGA DVI-D IPS LED Black Monitor
Delivery
Standard Due date unavailable
The ProLite XB2485WSU is a 24" LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all-round panel type. It offers accurate and consistent color reproduction with wide viewing angles and great response time. The ProLite XB2485WSU features 1920 x 1200 native screen resolution, has a 5 000,000:1 Advanced Contrast Ratio and 300 cd/m2 brightness offering the user clear and vivid images. An array of inputs including DisplayPort, DVI, VGA and USB connections ensure compatibility across a range of devices including games consoles and work stations.
Iiyama ProLite XB2485WSU-1 - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
56.1 cm x 24.45 cm x 41.6 cm
6.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI Class B ITE, DDC-2B, VESA DPMS, TCO Displays 5.0, TCO Displays 5.1, TCO Displays 5.2
Display Type
Diagonal Size
24"
Viewable Size
24.1"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 94 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, gamma correction, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Russian, Spanish, Dutch, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
6.4 kg
VGA , DVI-D , DisplayPort , Audio line-in , 4 x USB downstream , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management cover
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
36 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* iiyama prolite excellence
Reviewed by Wes on 07/08/2013
Having struggled to manipulate photos and design various electronic and print designs, I couldn't wait to get hold of a decent monitor. With 1900 x 1200 pixels available and correct drivers, the colour representations and clarity of image are second to none.
Photographs have suddenly obtained a richness I've never really seen until now.
Without doubt the best monitor I've ever used. *****
Scroll to top
