BT.com
Wishlist
iiyama ProLite X2888HS-B1 28" 1920x1080 5ms VGA DVI HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
The ProLite X2888HS is the latest addition to the range of monitors featuring VA Panel technology which offers superb color performance and wide viewing angles. This sophisticated technology provides 24 bit 'True Color' and superior black and white display performance. A 3000:1 Native Contrast Ratio offers great performance for displaying Black and White. X2888HS is therefore ideal for Photographic Design and Web-design. With the added support of a Low Power LED Panel, the iiyama ProLite X2888HS is also an excellent choice for Universities, Corporate and Financial Markets.
Iiyama ProLite X2888HS-B1 - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class A
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
31.9 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Tilt
66.3 cm x 24 cm x 46.35 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
47 kWh
31.9 W
Diagonal Size
28"
Viewable Size
28"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, auto-centre, blue reduction
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Mobile High-Definition Link (MHL), Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color
66.3 cm x 24 cm x 46.35 cm - with stand
5.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , DVI-D (HDCP) , HDMI , DisplayPort , Audio line-in , Headphone input
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable , 1 x audio cable
Power Supply
Internal
32 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
With stand - width: 66.3 cm - depth: 24 cm - height: 46.35 cm - weight: 5.3 kg , Without stand - width: 66.3 cm - depth: 6.05 cm - height: 38.35 cm
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
