BT.com
Wishlist
iiyama Prolite X2481HS-B 24" 1920x1080 VGA HDMI DVI LED Monitor
iiyama Prolite X2481HS-B 24"...
£185.17
£185.17
Add to wishlist
Delivery
Standard Due date unavailable
ProLite XB2483HSU-B2DP - a 24" LED backlit LCD screen featuring AMVA panel technology, delivers accurate and consistent color reproduction with wide viewing angles. Offering 24 bit 'True Color' and great performance for displaying black and white with the 3000:1 Native Contrast Ratio, means that the Prolite XB2483HSU-B2DP will provide excellent performance for photographic, design and web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
Iiyama ProLite XB2483HSU-B2DP - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
55.25 cm x 23 cm x 38.1 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, TCO Displays 6.0, VCCI Class B, CU
Display Type
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology
55.25 cm x 23 cm x 38.1 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , DisplayPort , Headphones (mini-jack) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable , 1 x DisplayPort cable
25 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
Dimensions & Weight Details
Without stand - width: 55.25 cm - depth: 5.65 cm - height: 33.4 cm , With stand - width: 55.25 cm - depth: 23 cm - height: 38.1 cm - weight: 5.6 kg
ENERGY STAR Certified
Other bundles
iiyama Prolite X2481HS-B 24" 1920x1080 VGA HDMI DVI LED...
£185.17
Wireless keyboard and mouse set
£235.16
£185.17
Keep your electronic devices protected
£205.16
Accessories
£7.95
£8.90
£12.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.94
£6.00
£8.53
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.43
£56.40
Scroll to top
