BT.com
Wishlist
iiyama ProLite TH4264MIS-B2AG 42" 1920x1080 9ms VGA DVI HDMI DisplayPort LED Large Format Display
Delivery
Standard Due date unavailable
Incorporating the InfraRed 10 point touch feature along with supreme panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments.
Iiyama ProLite TH4264MIS-B2AG 42" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class C
120 Watt
99 cm x 12.2 cm x 58.45 cm
23.6 kg
Energy Class
Class C
120 Watt
Diagonal Class
42"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
99 cm
12.2 cm
58.45 cm
23.6 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Brightness
400 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.4833mm x 0.4833mm
Touchpoints Qty
10
Response Time
9 ms
Colour Temperature Control
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Standard remote
Audio System
Audio Controls
Balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - built-in - 12 Watt
Connector Type
VGA input , DVI-D input , HDMI input , Serial output , Composite video input , S-Video input , Audio input , 2 x audio input , Component video input , Speakers output , Serial input , USB , VGA output , Composite video output , Audio output , Network
Pen stylus
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Scroll to top
