BT.com
Wishlist
iiyama ProLite TF2234MC-B1X 22" 1920x1080 5ms VGA DVI USB Touchscreen IPS LED Monitor
Delivery
Standard Due date unavailable
ProLite TF2234MC uses Projective Capacitive Touch technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with an IP54 Rating, making it dust and water resistant and with a rugged bezel making it suitable for demanding environments. The ProLite TF2234MC is the ideal screen for the kiosk integrators and a solution for interactive digital signage, instore retail, gaming and interactive presentations.
Iiyama ProLite TF2234MC-B1X - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
51.75 cm x 4.6 cm x 31.35 cm
4.4 kg
VCCI, VESA DPMS, IP54, TUV Bauart
Display Type
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Edge-to-edge glass, HID Compliant, Projected Capacitive Touch (PCT) technology
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , USB
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Water-resistant, dust-resistant
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
Power Supply
External
DC 12 V
27 Watt
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.63
£13.69
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.54
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.96
Scroll to top
