BT.com
Wishlist
iiyama ProLite TE5564MIS 55" 1920x1080 8ms DVI HDMI DisplayPort LED Large Format Display
Delivery
Standard Due date unavailable
Incorporating the InfraRed 10 point touch feature along with supreme IPS panel color performance, this display offers the optimum performance for a truly multi-user interactive experience. With the ability to handle up to 10 individual touch points, the TE5564MIS-B2AG offers an exceptional capacity within retail, education, training, corporate and B2B markets. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments. It also features an ambient light sensor delivering optimal picture quality with the added benefit of saving on power.
Iiyama ProLite TE5564MIS-B2AG 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Diagonal Size
54.6 in
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class A
143 Watt
127.1 cm x 11.05 cm x 74.2 cm
40.8 kg
Energy Class
Class A
143 Watt
Diagonal Class
55"
Diagonal Size
54.6 in
Combined with
Touchscreen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Landscape mode
Protection
Protection glass
Dimensions
Without stand
127.1 cm
11.05 cm
74.2 cm
40.8 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
1400:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Touchpoints Qty
10
Response Time
8 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x main channel speaker - built-in - 12 Watt
Connector Type
2 x HDMI , DVI-D input , VGA input , VGA output , Serial input , Serial output , Component video input , S-Video input , Composite video input , Composite video output , Audio line-in , Audio output , Audio input , USB , Network , DisplayPort input , DVI-D output , Speakers output
Pen stylus
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Scroll to top
