BT.com
Wishlist
iiyama ProLite T2452MTS-B4 24" 1920x1080 2ms VGA DVI HDMI USB Touchscreen LED Monitor
Delivery
Standard Due date unavailable
This monitor lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi-touch is not only fast but also fun to work with. The panel features High Definition 1920x1080 resolution with a fast response time. HDMI, DVI and Analog inputs are available for flexible connectivity along with USB for the Touch Interface.
Iiyama ProLite T2452MTS-B4 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22.5 W
Touch-screen, stylus
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
260 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
55.6 cm x 24 cm x 39.9 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, VESA DPMS, PSE Mark, GOST-R, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
33 kWh
22.5 W
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
260 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
55.6 cm x 24 cm x 39.9 cm - with stand
6.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Optical
VGA , DVI-D , HDMI (HDCP) , Headphones , USB
Mechanical
Tilt
Tilt Angle
-9/+22
Flat Panel Mount Interface
100 x 100 mm
Stand, stylus
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
Power Supply
Internal
22 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
With stand - width: 55.6 cm - depth: 24 cm - height: 39.9 cm - weight: 6.2 kg , Without stand - width: 55.6 cm - depth: 5.6 cm - height: 34.7 cm
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
