BT.com
Wishlist
iiyama Prolite T1634MC-B4X 16" 5ms VGA DVI-D USB Touch Display
iiyama Prolite T1634MC-B4X 16" 5ms...
£514.06
£514.06
Add to wishlist
Delivery
Standard Due date unavailable
The 15.6" LED-backlit ProLite monitor uses Projective Capacitive Multi-Touch technology, built into an eye catching bezel with edge-to-edge glass. The screen features DVI and VGA inputs and a rugged bezel front making it suitable for demanding environments. The ProLite monitor is the ideal solution for in-store retail and kiosk integration.
Iiyama ProLite T1634MC-B4X - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
400 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
38.1 cm x 20.2 cm x 28.55 cm
4.4 kg
VCCI, DDC-2B, VESA DPMS, IP54, TUV Bauart
Display Type
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
400 cd/m²
Brightness w/touchscreen
360 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60.3 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
38.1 cm x 20.2 cm x 28.55 cm - with stand
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB (Type B)
Mechanical
Tilt
Tilt Angle
-5/+90
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x USB cable
DC 12 V
16 Watt
Included Software
Drivers & Utilities
Microsoft Windows NT 4.0, Microsoft Windows 95/98, Microsoft Windows CE, Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
Without stand - width: 38.1 cm - depth: 5.3 cm - height: 23.05 cm , With stand - width: 38.1 cm - depth: 20.2 cm - height: 28.55 cm - weight: 4.4 kg
Scroll to top
