BT.com
Wishlist
iiyama Prolite LH5581S-B1 55" DVI VGA HDMI Commercial Display
iiyama Prolite LH5581S-B1 55" DVI...
£1,586.82
Hurry, only 2 left in stock!
£1,586.82
Add to wishlist
Delivery
Standard 1-3 working days
The professional appearance of the ProLite LH5581S incorporates a slim design featuring a sleek bezel. Featuring IPS panel technology this elegant display ensures amazing color accuracy and vivid, life-like quality from all angles. The LED-backlit technology provides low power consumption and reliable long-term operation. Built-in expansion slot supports the Open Pluggable Specification (OPS) standard, it simplifies the installation of a plug-in PC for digital signage applications. Landscape and Portrait friendly, ProLite LH5581S is designed for a continues operation. Perfect for true impact in Digital Signage and an ideal solution for a video wall set-up.
Iiyama ProLite LH5581S-B1 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class C
145 Watt
122.85 cm x 7.1 cm x 69.95 cm
24.7 kg
Energy Class
Class C
145 Watt
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
TV Tuner
No tuner
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design
122.85 cm
7.1 cm
69.95 cm
24.7 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1300:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Chinese
MPEG artifact reduction, Open Pluggable Specification slot, security lock slot (cable lock sold separately), Noise Reduction, remote lock
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
2 x HDMI , 2 x DisplayPort , DVI-D input , DVI-D output , VGA input , Component video input , Audio input , Serial input , Serial output , Remote control input , Remote control output , Network , Audio input , Audio output , USB 2.0 , 2 x speakers output , Audio output
DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , Serial cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
20 - 80% (non-condensing)
Scroll to top
