BT.com
Wishlist
iiyama ProLite LH4664S 46" 1920x1080 VGA DVI-D HDMI DisplayPort LED Large Format Display
iiyama ProLite LH4664S 46"...
£869.65
27 in stock
£869.65
Add to wishlist
Delivery
Standard 1-3 working days
Incorporating AMVA3 panel technology the LH4664S guarantees great viewing from all angles, high brightness and perfect color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Landscape and portrait friendly, the display can be mounted according to the application for true impact in digital signage.
Iiyama ProLite LH4664S-1 46" LED display
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
132 Watt
Power Consumption (On mode)
94.3 W
Energy Consumption per Year
138 kWh
105.1 cm x 8.4 cm x 60.55 cm
22 kg
Energy Class
Class B
132 Watt
94.3 W
138 kWh
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
105.1 cm
8.4 cm
60.55 cm
22 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.53025 x 0.53025mm
Response Time
6.5 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
200 x 400 mm
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - built-in - 12 Watt
Connector Type
VGA input , Composite video input , S-Video input , Composite video input , Audio line-in , DVI-D input , HDMI input , DisplayPort input , Audio input , Serial output , Audio output , VGA output , Composite video output , Remote control , Serial input
VGA cable , DVI cable
DDC-2B, VESA DPMS, CB, GOST-R, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Scroll to top
