BT.com
Wishlist
iiyama ProLite LH4264S 42" 1920x1080 DVI VGA HDMI LCD Large Format Display
Delivery
Standard Due date unavailable
Incorporating IPS panel technology the LH4264S guarantees great viewing from all angles, high brightness and exceptional color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Landscape and portrait friendly, the display can be mounted according to the application for true impact in digital signage.
Iiyama ProLite LH4264S-1 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class C
119 Watt
Power Consumption (On mode)
100 W
Energy Consumption per Year
146 kWh
98.05 cm x 10.5 cm x 57 cm
18 kg
Energy Class
Class C
119 Watt
100 W
146 kWh
Diagonal Class
42"
Commercial Use
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
98.05 cm
10.5 cm
57 cm
18 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Brightness
400 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.4833mm x 0.4833mm
Response Time
9 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
200 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - built-in - 12 Watt
Connector Type
VGA input , Component video input , S-Video input , Composite video input , Audio line-in , DVI-D input , HDMI input , DisplayPort input , Audio input , Serial output , Audio output , VGA output , Composite video output , Network , Serial input , Speakers output
VGA cable , DVI cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Scroll to top
