BT.com
Wishlist
iiyama ProLite LE4041UHS-B1 40" DVI VGA HDMI Commercial Display
iiyama ProLite LE4041UHS-B1 40" DVI...
£773.65
£773.65
Add to wishlist
Delivery
Standard 1-3 working days
The ProLite LE4041UHS is an excellent 4K (3840 x 2160) monitor, offering a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch) the monitor displays an incredibly sharp and crisp image. The VA panel technology offers exceptional color performance, high contrast (5000:1) and wide viewing angels. The display supports PIP function, which allows users to watch images coming from different sources.
Iiyama ProLite LE4041UHS-B1 40" Class (39.5" viewable) LED display
LED-backlit LCD flat panel display
Energy Class
Class B
61 Watt
Power Consumption (On mode)
64.4 W
Energy Consumption per Year
94 kWh
Diagonal Class
40"
Diagonal Size
39.5 in
Commercial Use
Yes - digital signage
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
Modes
Landscape mode
Design
Metal frame
Dimensions
Without stand
92.15 cm
6.95 cm
52.85 cm
15.6 kg
Enclosure Colour
Display
LCD Display Technology
MVA
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LCD Backlight Technology
LED backlight
Colour Depth
1 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
12000000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.229 x 0.255mm
Response Time
4 ms
Display Menu Language
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
Stands & Mounts
Flat Panel Mount Interface
200 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
12 Watt
Speakers
2 x main channel speaker - built-in - 6 Watt
Connector Type
2 x HDMI , DVI-D input , VGA input , DisplayPort input , DisplayPort output , Audio line-in , Audio line-out , Serial input , Serial output
VGA cable , DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , Serial cable , Audio cable
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Power supply
Nominal Voltage
AC 100/240 V (50/60 Hz)
On / Off Switch
Scroll to top
