BT.com
Wishlist
iiyama Prolite LE3240S-B1 32" 8ms VGA DVI HDMI USB LCD Display
iiyama Prolite LE3240S-B1 32" 8ms...
£357.18
£357.18
Add to wishlist
Delivery
Standard Due date unavailable
ProLite LE3240S is a 32'' Full HD, professional and fan-less LED-backlit display. Incorporating the latest Commercial Grade IPS panel technology, the display guarantees great viewing from all angles, high brightness and exceptional color clarity. A wide range of video and audio inputs ensures compatibility with multiple platforms. ProLite LE3240S is prepared for easy installation using the VESA wall mount. This display will suit a massive range of applications including public signage, retail, exhibitions and conference centers, POS/POI, control rooms and production facilities.
Iiyama ProLite LE3240S-B1 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display
Energy Class
Class B
42 Watt
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
TV Tuner
No tuner
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Landscape mode, Eco mode
Picture Enhancements
Pixel Shift
Timer Functions
Sleep
Dimensions
Without stand
72.65 cm
6.35 cm
42.52 cm
5.2 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LCD Backlight Technology
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1400:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.364 x 0.364mm
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, bass, treble
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI input , DVI-D input , VGA input , Component video input , Audio line-in , Audio line-in , Audio line-out , Serial input , Serial output , Remote control input , Remote control output , Network , USB 2.0
VGA cable , DVI cable , Serial cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
AC 100/240 V (50/60 Hz)
On / Off Switch
Auto On/Off
WOL (Wake on LAN)
Scroll to top
