Click to visit BT.com
BT.com
Wishlist
iiyama ProLite G2773HS-GB1 27" 1920x1080 1MS HDMI VGA & Dual Link DVI Gaming Monitor with Speakers
Quicklinx: 8JS5WS00
Mfr#: G2773HS-GB1
Essential accessories
The 27'' ProLite G2773HS is a real game changer. The use of a high quality 120Hz panel with a blistering 1ms Response Time offers you an amazing gaming experience. The screen offers crystal clear, smooth and judder free graphics during fast paced games and beautiful quality HD video. Hardcore gamers will really appreciate the few milliseconds advantage this screen gives you, allowing split second game changing decisions. The screen comes equipped with stereo speakers and a headphone socket as well as HDMI, VGA and Dual Link DVI connections and boasts a 1920 x 1080 Resolution. The LED Back Light system offers great clarity and brightness.
120Hz REFRESH RATE
The use of a high quality 120Hz panel guarantees a flawless gaming experience - less fracturing, smoother graphics motion during fast paced games and judder free animations. For 120fps game-play it is required to have a graphic card that supports dual link 120Hz DVI.
LED-Backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
Speakers
This LED monitor is equipped with two high quality stereo speakers.
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
OverDrive ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Iiyama ProLite G2773HS-1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080 at 120 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
64.7 cm x 23.9 cm x 45.5 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI Class B ITE, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart
Display Type
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
120 Hz
Horizontal Refresh Rate
140 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Finnish, Spanish, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2.5 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management clip
1 x HDMI cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
35 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
