BT.com
Wishlist
iiyama ProLite E2473HS-GB1 23.6" 1920x1080 2ms VGA HDMI LED Monitor with Speakers
Delivery
Standard Due date unavailable
The ProLite E2473HS LED-backlit monitor is a FHD (1920x1080) 24" display with high specifications, triple input connectivity (VGA, DVI and 2xHDMI) and fast 2ms response for excellent sharpness in high definition. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensure great comfort of usage and the X-Res Technology feature helps to deliver best quality pictures even if the source is not perfect, like movies made with mobile device.
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
X-Res Technology
The X-Res Technology feature enhances pictures quality making sure they always look vivid and natural. Especially handy when enlarging lower definition pictures with rough edges, the feature helps to deliver better quality pictures giving the viewer a sense of higher resolution.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
LED-BACKLIT
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
OverDrive ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that*
Iiyama ProLite E2473HS-1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23.4 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
55.6 cm x 21.85 cm x 41.8 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI Class B ITE, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart
Display Type
Energy Class
Class A
34 kWh
23.4 W
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology
4.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , 2 x HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management clip
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
22 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
Accessories
£9.99
£7.24
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£12.66
£38.88
£52.69
Scroll to top
