BT.com
Wishlist
iiyama ProLite E2283HS 21.5" 1920x1080 2ms VGA DVI-D HDMI LED Monitor
Delivery
Standard Due date unavailable
The ProLite E2283HS is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 2ms response time and more than 5000000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The E2283HS is also equipped with two high quality stereo speakers.
Iiyama ProLite E2283HS - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
50.55 cm x 19.3 cm x 38.25 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, TCO Displays, VCCI Class B
Display Type
Energy Class
Class B
32 kWh
21.8 W
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
21 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
