BT.com
Wishlist
iiyama ProLite E2280HS 22" 1920x1080 5ms HDMI DVI-D VGA Black Monitor with Speakers
Select:
Delivery
Standard Due date unavailable
The ProLite E2280HS is a 21.5" Full HD 1920 x 1080p LED-backlit monitor. It features 5ms black-to-black response time and >5,000,000: 1 advanced contrast ratio assuring very good picture quality. Triple input support of analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is ENERGY STAR Certified. It offers a reliable solution for both home and office use.
What's in the box
  • Iiyama ProLite E2280HS-1
  • DVI cable
  • Audio cable
  • Stand
  • Software
iiyama ProLite E2280HS-1 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
23.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2482 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
50.95 cm x 18.95 cm x 36.55 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS
Display Type
Energy Class
Class B
35 kWh
23.8 W
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2482 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
3.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-4/+21
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
21 Watt
Power Consumption Stand by / Sleep
1 Watt
0.5 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Accessories
Accessories
£124.77
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£116.11
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£83.23
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£51.62
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£71.73
Other bundles
£9.99
£7.75
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£26.02
£49.75
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£62.13
Scroll to top
