BT.com
Wishlist
iiyama ProLite E2083HD-B1 19.5" 1600x900 5ms VGA DVI-D Black LED LCD Monitor
Delivery
Standard Due date unavailable
The ProLite E2083HD is a 19.5" LED-backlit monitor with 1600 x 900 resolution. It features 5 ms response time and more than 5M:1 advanced contrast ratio assuring vibrant images and blur free video. Analog VGA and digital DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is ENERGY STAR qualified and VESA mount compatible. It is a reliable solution for both home and office use.
Iiyama ProLite E2083HD-B1 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
46.95 cm x 20.3 cm x 36 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST-R, TCO Displays, VCCI Class B
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, phase, clock, luminance
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Advanced Contrast Ratio (ACR)
2.6 kg
DVI-D , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable
Power Supply
Internal
15 Watt
Power Consumption Stand by
0.5 Watt
Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
ENERGY STAR Certified
Accessories
£8.20
£9.19
£12.16
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.30
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£43.70
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.71
£58.90
Scroll to top
