BT.com
Wishlist
iiyama ProLite B2783QSU-B1 27" 2560x1440 1ms DVI-D HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
The ProLite B2783QSU is an excellent 27" QHD LED-backlit monitor bringing the world of business and gaming together. The monitor offers accurate and consistent color reproduction with wide viewing angles and a sharp high resolution panel. Its ergonomic stand offers 13 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. This monitor features FreeSync technology, offering gamers the chance to experience fluid and fracture free gaming. Triple input and a USB hub ensure compatibility with your desktop PC or notebook.
Iiyama ProLite B2783QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
43 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2333 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
62.25 cm x 23 cm x 40.05 cm
6.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B
Display Type
Energy Class
Class B
62 kWh
43 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2333 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
Controls & Adjustments
Volume, brightness, contrast, sharpness, input select, colour temperature
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), blue light reduction, i-Style Color
62.25 cm x 23 cm x 40.05 cm - with stand
6.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D , HDMI , Headphones , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-in
Mechanical
Tilt Angle
-5/22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable
44 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
Without stand - width: 62.25 cm - depth: 5.65 cm - height: 37.25 cm , With stand - width: 62.25 cm - depth: 23 cm - height: 40.05 cm - weight: 6.1 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
