Click to visit BT.com
BT.com
Wishlist
iiyama ProLite B2080HS-B1 20" 1600 x 900 5ms VGA DVI-D Height Adjustable Black Monitor with Speakers
Quicklinx: 8DRCWS00
Mfr#: B2080HSD-B1
The ProLite B2080HSD is a 20" 1600x900 LED-backlit monitor with a Height Adjustable Stand supporting Screen Rotation, ensuring perfect posture and optimal viewing comfort. It features 5 ms black-to-black response time and 5 000 000:1 Advanced Contrast Ratio assuring very good picture quality. Analog and DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is TCO and Energy Star Certified. A perfect solution for education, local government, business and finance markets.
Iiyama ProLite B2080HSD - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.2768 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
47.8 cm x 24.45 cm x 37.55 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, TCO Displays 5.0, TCO Displays 5.1, TCO Displays 5.2
Display Type
Diagonal Size
20"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.2768 mm
Brightness
250 cd/m2
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management cover
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
16 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Driver
