BT.com
Wishlist
iiyama Prolite 24" 1920x1080 VGA DVI-D HDMI LED Monitor - Black
ProLite E2483HS – a Full HD LED monitor with 2 ms response time
Delivery
Standard Due date unavailable
The ProLite E2483HS is an excellent 24" full HD LED-backlit monitor with 1920 x 1080p resolution. It features 2ms response time and more than 5000000:1 advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the installed graphics cards and embedded notebook outputs. The E2483HS is also equipped with two high quality stereo speakers. Energy Star and TCO certified, this monitor is a reliable solution for both home and office use.
Box Contains
  • 1 x Iiyama ProLite E2483HS-1 monitor
  • AC adapter
  • 1 x DVI cable - DVI-D to DVI-D
  • 1 x audio cable
  • Driver
FLICKER FREE + BLUE LIGHT
The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
SPEAKERS AND HEADPHONES
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
OVERDRIVE ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
Iiyama ProLite E2483HS-1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
56.55 cm x 20.3 cm x 41.2 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, TCO Displays, VCCI Class B
Display Type
Energy Class
Class A
36 kWh
24.9 W
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
3.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
Accessories
Accessories
£138.85
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£122.23
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£83.23
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£54.34
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£78.40
Other bundles
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
