BT.com
Wishlist
iiyama LH5580S 55" 1920x1080 VGA DVI-D HDMI LED Large Format Display
Delivery
Standard Due date unavailable
Full HD professional, feature-rich and robust, Iiyama's large format screen is designed in 55" sizes and with or without multi-touch functionality. The displays offer an exceptional capacity within retail, education, training, corporate and B2B markets. Incorporating the IPS panel technology, the display guarantee high brightness, exceptional color clarity and great viewing from all angles. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. An ambient light sensor delivers exceptional performance with the added benefit of saving on power. Landscape and portrait friendly, the display can be mounted according to the application for true impact in interactive digital signage.
Iiyama ProLite LH5580S-1 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class A
133 Watt
Power Consumption (On mode)
102.6 W
Energy Consumption per Year
150 kWh
124.7 cm x 6.65 cm x 71.8 cm
28.5 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class A
133 Watt
102.6 W
150 kWh
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
124.7 cm
6.65 cm
71.8 cm
28.5 kg
Enclosure Colour
Display
LCD Display Technology
AMVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
VGA input , S-Video input , Composite video input , Audio line-in , DVI-D input , 2 x HDMI input , DisplayPort input , Audio output , Speakers output , Composite video output , Network , Serial output , Serial input , Speakers output , DVI-D output , 2 x USB 2.0
VGA cable , DVI cable
VESA DPMS, CB, TUV Bauart, EAC
Power supply
Nominal Voltage
Power Consumption Stand by
1 Watt
Scroll to top
