BT.com
Wishlist
iiyama G-Master GE2788HS-B2  27" 1920x1080 VGA DVI HDMI 1ms Monitor
iiyama G-Master GE2788HS-B2 27"...
£185.32
£185.32
Add to wishlist
Delivery
Standard Due date unavailable
The 27" G-MASTER GE2788HS known as Black Hawk is the perfect companion at your side. Hard-bitten and trust-worthy, it will make your enemies shiver. Famous for being a very capable hunter with extremely good vision the Black Hawk, armed with FreeSync technology, eliminates your enemies with a stunning 1 ms response time. And if darkness falls across the land, the Black Tuner function allows you to adjust brightness in the dark shades enhancing detail in shadowed areas making sure no foes remain unseen. So login to the world of games, put on your headset and immerse yourself in your favorite game displayed in beautiful clarity.
Iiyama G-MASTER Black Hawk GE2788HS-B2 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32.2 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
64.35 cm x 24.2 cm x 46.2 cm
4.6 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, WEEE, TUV Bauart, CU
Display Type
Energy Class
Class B
47 kWh
32.2 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, FreeSync Technology, Black Tuner
64.35 cm x 24.2 cm x 46.2 cm - with stand
4.6 kg
Audio
Speakers - stereo
Output Power / Channel
2.5 Watt
DVI-D (HDCP) , HDMI (HDCP) , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x HDMI cable , 1 x audio cable
30 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 64.35 cm - depth: 5.45 cm - height: 38.2 cm , With stand - width: 64.35 cm - depth: 24.2 cm - height: 46.2 cm - weight: 4.6 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
Other bundles
iiyama G-Master GE2788HS-B2 27" 1920x1080 VGA DVI HDMI...
£185.32
Wireless keyboard and mouse set
£235.31
£185.32
Keep your electronic devices protected
£205.31
Accessories
£7.95
£8.90
£12.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.94
£6.00
£8.53
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.43
£56.40
Scroll to top
