BT.com
Wishlist
iiyama 65" 1920x1080 8ms VGA DVI-D HDMI DP USB LED LFD
Delivery
Standard Due date unavailable
The ProLite TH6564MIS-B2AG is the perfect solution for educational and corporate use. The high quality commercial AMVA3 LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The solid and robust design is capable of withstanding the requirements of highly-demanding environments. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The anti-glare feature drastically reduces ambient reflection in high brightness environments without compromising the sharp clarity of the content. By using a finger or stylus, you can write, annotate, draw and present with confidence.
Iiyama ProLite TH6564MIS-B2AG 65" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class C
255 Watt
Power Consumption (On mode)
232 W
Energy Consumption per Year
339 kWh
152.1 cm x 11.1 cm x 83.3 cm
64.1 kg
Energy Class
Class C
255 Watt
232 W
339 kWh
Diagonal Class
65"
Commercial Use
Combined with
Touch-screen
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode
152.1 cm
11.1 cm
83.3 cm
64.1 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.744 x 0.744mm
Response Time
8 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Multitouch, infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Audio Controls
Balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - built-in - 12 Watt
Connector Type
VGA input , DVI-D input , HDMI input , DisplayPort input , Composite video input , S-Video input , Audio input , Audio input , Component video input , Remote control , Serial , USB , VGA output , Composite video output , Audio output
Pen stylus
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
0 - 85% (non-condensing)
Scroll to top
