BT.com
Wishlist
iiyama 55" Black LED Large Format Display 1920 x 1080 18/7 500
Delivery
Standard Due date unavailable
Incorporating the improved infrared 10 point touch feature along with supreme panel color performance, this display offers the optimum result for a truly multi-user interactive experience. With the ability to handle up to 10 individual touch points, the display offers an exceptional capacity within retail, education, training, corporate and B2B markets. Its characteristics include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. It also features an ambient light sensor, delivering optimal picture quality with the added benefit of saving on power. Incorporating protection glass and AG-coating, the display can handle harsh environments from the classroom to public domain retail installation. Landscape- and portrait-friendly, a perfect solution for interactive digital signage.
Iiyama ProLite TH5564MIS-B3AG 55" Class ( 54.6" viewable ) LED display
LED-backlit LCD flat panel display with touch-screen
Diagonal Class
55"
Diagonal Size
54.6 in
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
120Hz Refresh Rate
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 120/230 V ( 50/60 Hz )
Energy Class
Class B
150 Watt
Power Consumption (On mode)
117 W
Energy Consumption per Year
171 kWh
127.1 cm x 11.05 cm x 74.2 cm
43.1 kg
Energy Class
Class B
150 Watt
117 W
171 kWh
Diagonal Class
55"
Diagonal Size
54.6 in
Combined with
Touch-screen
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Film Mode, portrait mode, landscape mode, Picture mode
Protection
Protection glass
Dimensions
Without stand
127.1 cm
11.05 cm
74.2 cm
43.1 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Coating
Anti-glare
Image Contrast Ratio
4000:1
Brightness
445 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
6.5 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Infrared multitouch technology, Noise Reduction
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x main channel speaker - built-in - 12 Watt
Connector Type
Network , Serial input , Serial output , DisplayPort , DVI-D input , DVI-D output , 2 x HDMI , Component video input , S-Video input , Composite video input , Composite video output , Audio output , Audio input , Audio input , VGA input , VGA output , Speakers output , USB
Pen stylus, sticker
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, CB, WEEE, TUV Bauart, ERP, EAC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
0 - 85% (non-condensing)
Scroll to top
